I think maybe I have reported this before, this is the way Text opens on my 4K screen.
V7
WIP
I have to pull the box down to expose the text entry area. This is only on first opening, after that it seems to be OK, even between sessions, but it’s a bit disconcerting and I think it should be fixed. Hence the “Papercut” category.
Are you running multiple screens at different resolutions?
Assuming yes, what happens if you set them to the same resolution?
Nope, two 4K resolution screens, native resolution on both. 150% display scaling (the recommended value).
@JohnM
Any ideas for Mitch on this problem?
Alain
(Alain Cormier)
March 21, 2022, 8:42am
6
Hi Mitch,
Once you’ve correctly resized the dialog are you able to make it smaller again? Normally that shouldn’t be possible.
Yep.
Guess we’re not ‘normal’ here…
(note I just posted another text edit box anomaly in a different thread)
Alain
(Alain Cormier)
March 21, 2022, 9:21am
8
Hmm, not sure what’s going on.
logged: RH-67935
Thanks
curtisw
(Curtis Wensley)
April 18, 2022, 11:32pm
9
@Helvetosaur hey, I’ve been looking into this and can’t seem to reproduce it. Could you run SystemInfo
and post it here? Also the output of TestSystemScreenInfo
would be very helpful.
Hi @curtisw -
I can’t seem to make it happen anymore currently either… One-shot deal? Somehow got fixed in the last month?
Here are the two info files (from the 12.04 WIP) anyway, just in case:
MSH-SysInfo-WIP-19-04-22.txt (2.6 KB)
RhinoSystemScreenInfo-MSH-WIP-19-04-22.txt (904 Bytes)
curtisw
(Curtis Wensley)
April 25, 2022, 3:40pm
11
@Helvetosaur great to hear it’s working now. One thing that it could be is changing the screen scale while Rhino is running, which I have yet to test.
