Text Command Bug
When I run the text command I get the dialog box showing all the text settings, but I can’t see what I am typing until I hit OK.
Resize the dialog from the lower-right corner to a larger size.
Reported as https://mcneel.myjetbrains.com/youtrack/issue/RH-45443
I have reported this earlier, so there is at least one duplicate yt item for this…
I just barely moved it, and the display box showed up.
I’m running 2560 x 1440, if that helps.
Thanks,
Don
I failed to find the YT issue. If you know the ID let me know, then I can combine them. Thanks.
I can’t either anymore - maybe I forgot to report it… :frowning:
I also thought it was reported, but maybe we both forgot Back Then. Well, it is reported now!
Dialog sizes varied a lot during development and Rhino remembers the sizes so I’m wondering if Rhino is reading old settings from that period. I’ll investigate
I think this shows up when no settings are available yet. Resizing is needed only once, then window will remember that new size.
RH-45443 is fixed in the latest Service Release Candidate
