Inside V8 the text object box will not display the text that I am trying to use in a model. Not sure if it’s a bug or inadvertently toggle something off?
Hi user2498,
Please run the Systeminfo in your Rhino command line and post the result.
There is a Reset command that may help here as well. Thanks
Thanks for the assist…
Here is system info grab.
Also, Tried reset in command but still no line in the text object box
system_info grab.txt (2.4 KB)
Hi 2498 -
It looks like the field that displays the text is collapsed. Try resizing the dialog to see if that clears that up.
