since I switched from Rhino5 to Rhino6, somehow text objects in the layouts aren’t visible any more. Neither dimensions nor simple text. As you can see in the picture there is somehow an object, but won’t show the text. Changing scale and text height doesn’t help. Also new installation of rhino didn’t help.
Only when I wan’t to print the layout, then the text is visible again.
You might want to update your GUP(video card) driver.
Did you already update Rhino to the latest SR?
Can you paste the result of the command SytemInfo here? This will give an insght of your setup and might point out some issues eg with said drivers and versions.
Oops, I’ve updated it (latest updated 2015 -> because of Windows7)
Unfortunately it’s still not working.
It’s probably something with my hardware. Because I de/-reinstalled rhino and didn’t change any settings. And the CAD-file is working properly on my colleagues laptops with rhino6 (also Windows7).
Un-checked the box and restarted Rhino, but unfortunately nothing changed.
When I zoom far away, something appears which looks like dimension text. But when I zoom in again, it disappears.
