Text modifications in the properties panel doesn't work
Text modifications in the properties panel doesn’t work.
Thanks, - here it looks like it works, sort of, but does not correctly update the text - if I change the size, nothing happens until I also change the font style, for example.
http://mcneel.myjetbrains.com/youtrack/issue/MR-1867
@pascal
are you on the latest version of rhino for mac?
i’m not sure if this is what serbruba is referring to or not but:
a few versions ago: build 5A751
recent release: build 5A783
we used to be able to change the letters of the text in the properties->text panel… that editing field is no longer there.
edit- i suppose what i’m reporting is the same thing @Fred_W is noticing in his thread here:
On the pile as:
http://mcneel.myjetbrains.com/youtrack/issue/MR-1868
Wrong comment - sorry.
The screen shot below is accurate in that the box that shows the contents of the text (editing field) is collapsed.
Fred Wilmers
