Help: Cannot edit text
I’ve been trying to edit some of the text on my document. Some of the text doesn’t allow me to edit. From my observation, these are text that are made in different rhino file that I copied and pasted in the file. Is this the bug or am I doing something wrong?
Hi Megan - could you provide a 3dm file with that text object that refuses to change?
I have the same issue with text on the Layout. In my case the file also originated from a previous version.
The Drawing name should be updated with the file-name; (error 1) and it is also not possible to modify the other text fields. (error 2) Text error.3dm (5.4 MB)
I can not repeat the problem.
I can select existing Text on your layout, and in the Properties inspector panel, set for Text, I can scroll down and edit the text without any issues.
Can you provide a specific sequence you are trying that isn’t working?
I’m running V6 SR 29 on a 15" MBP running Catalina 10.15.6, no external monitors.
Try saving restarting Rhino. I have found frequently that, after pasting text, Rhino will not let me edit it,
