Is there an easy way to wrap text boxes with the ‘filename’ text field?
Classic issue of needing full filename path in my drawings, but having to reduce text size to miniminipt size to fit…
I’m still running the 5/22/17 build of v5. Maybe this has been addressed in something more recent?
Thank you!
edit: this is for %<"filename>%. A long string doesn’t wrap.
Hello - no, I don’t think so - it looks like forcing the wrapping messes up the fX field, right, at least in v5. I’ll check 6…
No, this does not work in 6 either. I’ll put it on the heap, but I can see how it might be a hard one to fix. https://mcneel.myjetbrains.com/youtrack/issue/RH-43510
