I get the Text Objects nicely placed on points in Rhino 7 but any editor box does not show up. Is there another way altogether to place text that you can edit?
Hi Ingemar -
When you use the TextObject
command, you create curves or surfaces. When you use the Text
command, you create text that you can edit later.
Thank you Wim, very easy now!
I feel like an idiot in this forum being a relatively new user. Rhino has so much power and potential but is also complex sometimes; for the same reasons probably.
However, things like these texting issues should be easier to find in a manual without bothering people in the forum.
