Tekla Grasshopper Component ⭮ - wall layout connector
Hi There,
I am learning and testing Grasshopper in Tekla
I came up with problem with tekla component Wall layout connector in Grasshopper. I cant make it to work.
What I did so far?
Checked inputs and deconstructed wall layout component for input.
Created wall layout, got the correct input , but cannot get it to work
I tried to connect also just 2 simply chosen model objects, also didn’t work.
Can you help? What I am missing?
If you zoom in to the Plugin-input component and add another input and then keep the inputs on the same branch it will work fine.
I manually place one and checked the input and they are on the same branch.
Hope this help!
