Component of Grasshopper run - Tekla is closing
Hi everybody!
I have a bug :unamused: when I run a component in the grasshopper- tekla is closing
How to solve this bug?
I will be glad of any help
Does it work if you unplug the profile input?
If not, are you able to share the part of the definition leading up to that component, with the input curves internalized so that we can try to replicate?
Cheers,
-b
The solution was found - the algorithm was copied to a new file and the bugs disappeared
Strange, but good to hear you got it working!
-b
