Grasshopper component
Hi, I am using the student version of Tekla Structures 2025 and Rhino 8 with Grasshopper. I create models using Grasshopper live in Tekla. However, when I try to open the Grasshopper component in Tekla after closing Rhino and Grasshopper, the component does not appear in the Applications and Components tab in Tekla, and I cannot find it using the search function either.
What should I do to fix this?
Thank you in advance.
Change the thread title to provide a hint of what this is about.
Hi Fikre, the Grasshopper Component for Tekla Structures is a separate download - did you already try to install it?
Link here (you might need to click it again after logging in):
