Hi All
Is there a chance to get bolts implemented in Tekla link ?
It seams only option is missing as there no packages available with this feature in latest version?
Regards
Hi All
Regards
you can use also the “Auto Bolt” component from Tekla.
Hi, bolts aren’t supported for now due to technical challenges (the work plane needs to be changed temporarily while inserting the bolts which messes up the execution of other components).
The workarounds suggested by Sajesh and PGyZ are the way to go. There are some examples here of using the Auto Bolt component, check out ClipAngle.gh and Glulam Arch.gh:
https://drive.google.com/drive/folders/1bNH1OfNZui8PqnN7BYctzNQWRLMsp9Vn?usp=sharing
Cheers,
Sebastian
