Hi Everyone. (@sebastian.lindholm
)I am trying to create assemblies using GH component, but I am getting this error message : “1. Objects param: Input object of type Seam could not be converted to IAssemblable”
My goal is to create 1 assembly per frame, so each frame has 2 columns, 6 horizontal bracings, 5 diagonals bracings and 2 baseplates. All braces and baseplates are Tekla components with their bolts. If I manually do it in Tekla, it works fine. But it looks like GH Tekla Live link does not like Seam components, detail components or bolt arrays as input for objects in an assembly.
I also tried to decompose the component and use its created objects as input, but this approach throws an error “1. Objects param: Input object of type Bolt Array could not be converted to IAssemblable”.
Is this a GH limitation or am I missing something? Can you tell me what types of objects are allowed for inputs in GH assembly component? or which one are not? I am using Rhino 8 with Tekla 2024.
Thanks.
