In technical views, I can hide creases, but it seems to only work on objects that are periodic (or maybe there are other criteria, but that’s what I suspect so far.) I’d like to be able to hide edges between joined surfaces where surfaces intersect with G1 continuity or greater (or to be able to hide edges based on an angle.)
Is this possible now? I’ll attach an image (the image is of a cylinder boolean
