(Technical drawings) Section views, plans, exploded views?
Automated exploded views can be generated with the command TestScalePosition
To create these kind of technical drawings you could use Layouts, which can be a combination of “Layout Details” similar to Named Views, in 2D. Each detail can be shaped, both in size and in arrangement of the model (orthographic/parallel, perspective, hidden layers or objects, special display modes of selected objects). Sections can be obtained using Clipping Planes, but whether these can be specific for Layout Details or just general for the entire model I don’t know. Layout details can be overlapping, only the visible objects will be printed, there is no background fill.
Don’t know about isometric presentation, I will do some testing.
Examples: on the Layouts UI:
in print:
You can add Borders, Title Blocks, Annotation and the like by “deactivating” all Layout Details and work on the Layout Page in 2D.
Max.
