Maybe I’ve missed something. But something seems up with the Sweep2 Output SubD option. It seems to sort of remember the structure of making a NURBS surface, and applies to the next created SubD. And actually even creates two different surfaces from the same picked stuff. SO maybe something under the hood going on? Guessing it’s something to do with refit maybe - the dense SubD fits the rail, the other maps CVs to Cage points
You’re welcome - glad to have noticed, and thanks for taking the time to repeat. I had noticed sometimes I got SubD Sweep2s that followed the rails and some that didn’t at random.
Do you think the Output SubD will remain integrated within vanilla Sweep2, or that a SubD Sweep might be peeled off like for loft?
Hi @Jonathan_Hutchinson the reason some of your curves fit and some do not depends on the curve structures. We call these “SubDFriendlyCurves”. You can read more about what makes a curve SubD Friendly here.
Hi Trav - this seems to be halfway there. The surface output is coming out right everytime as it would be expected, regardless of whether or not you have output a SubD the previous time.
But with the SubD output, only the dense version is possible (albeit, a version which doesn’t fit the rails perfectly as your example).
Thanks for the info - got it. I would maybe argue for allowing the simple option - it wasn’t so much that the result was a problem in the reported bug, but rather that it would yield completely different results with the same options. Someone mixing workflows might end up with an unnecessarily complex NURBS result.
Maybe someone else will chime in if they would like having that cleaner option available, if explicitly desired. @BrianJ ?
