Can anybody help me with subdsweep1?
Is there an option to just not adjust the rails? I just want to use the cage topology to make this sort of operation, even better would be to do it with a two segment (chained) cross section curve.
The produced surface seems a bit pointless to me.
Also, I think the stitch should be amended to say “set of edges or vertices”. Stitch can be helpful to join up faces that are close but not actually joined. And since at the moment, if two points are close together, you can’t easily select the two different points in separate clicks (no indication of which one was picked first). So, a dragged window around the area is better.
