As the title says, a SubD friendly curve after a point added does not extrude into a SubD
Is this the way it should be as it can be confusing ?
Cheers
Joao
Cheers
Joao
Hi Joao -
The title doesn’t actually specify all the assumptions that you are making, but anyway…
I’m sure it can be confusing, but, yes, this is by design.
When you edit a curve that was created with the SubDFriendly=Yes option, it gets demoted from “SubD friendly+” to “SubD friendly”.
Only curves that are “SubD friendly+” will automatically create SubD objects when extruding with the gumball.
Note:
MakeSubDFriendly or Rebuild commandsExtrudeCrv command and setting the Output option to SubD.Further reading - RH-58784
Thank you for the detailed explanation Wim
Joao
