Sweep2rails conversion to subD - Rhino 7
Dear all,
I am using Rhinocerosos 7 Beta.
I need to create surfaces based on sweep 2 rails and transform them into Sub D.
In correspondence with the parts where the tracks are curved the subDs show an incorrect trend, there is an inconsistent duplication of vertices.
I tried to use ARCO, SPLINE type curves and also to convert the two types to SUBD FRIENDLY CURVES.
The result after converting surfaces to SubD is always incorrect, with a lot og jagged part!
Is it a software problem?
Do you know if I can improve my results in someway?
Attached you will find a document in which you can see step by step my tests and results.
Thank you in advance for the help.
Laura
Apparently your document attachment didn’t succeed. I see no link in your post.
Sorry,
I try again.
problem_sweep2railsTOsubD.pdf (732.9 KB)
Can you see it now?
Thanks in advance for any help.
Laura
Hi Laura -
Please post a 3dm file.
Also, why do you want to convert to SubD and not just create SubD objects directly from the input curves?
I need to model the surface becuse I’m testing for research poupose a working pipeline based on step curve>surface>subD, using script.
Here the 3dm file:
test_02.3dm (1.1 MB)
:slight_smile:
Laura
Example:
Wonderfull!!!
How do you obtain this good result?
Did you started from the last surface model of the first line (joined binary based on line + control point curve subD friendly)?
Many thanks for your help.
Laura
Example:
Dear Inju,
thanks a lot for your suggestion.
Unfortunatly, I woud like to skip the step through the ‘quadremesh’ function.
My aim is to get a subD with a very low net polygon count.
For this reason I’m tring to use only the ‘Converto to SubD’ tool.
Laura
:wink:
SubDSweep2 is new Rhino 7 command. This command sweeps a shape curve along two rail curves to create a SubD.
:slight_smile: thanks
I’d say your sub-d friendly curve wasn’t sub-d friendly yet. I moved the section curve in the middle down to the control point and got this sub-d with the SubDSweep2 command:
test_02.3dm (59.3 KB)
thanks for your suggestion.
Laura
