Hi all,
when i use the command sweep2 and subdsweep2 i have a different result from what I expect.
Green crv is the silhouette and the red crv is what i think it should be.
Am I missing something?
Sweep 2.3dm (156.5 KB)
Hi all,
Hi Patrick, You could use Network Surface here and then convert to SubD. —Mark
I need to control the number of division in U and V
I think you may get closer to the expected result with EdgeSrf ; Surface > Edge Curves from the menu.
What about using SubD?
Start with EdgeSrf, then ToSubD with SurfaceCorners=Yes
