Adjusted rail segments:in SubDSweep2 doesn't work for same value
Adjusted rail segments:in SubDSweep2 doesn’t work for same value
Rhino 7 SR0 2020-8-11 (Public Build, 7.0.20224.11375
SubD sweep2.3dm (64.6 KB)
And @BrianJ I suggest adding the SubDNetwork command to the next updates
Thanks to the features that are regularly added to the subd
Thanks, filed that as https://mcneel.myjetbrains.com/youtrack/issue/RH-59990 . If you rebuild those curves in the meantime to have more segments (20 or so) it looks like you can use much higher values without issue.
Regarding a SubD version of NetworkSrf, I filed this a while back https://mcneel.myjetbrains.com/youtrack/issue/RH-57618 and it’ll get looked into at some point. SubDSweep2 gets you pretty close now.
RH-59990 is fixed in the latest WIP
