I’m modeling an architectural building that uses some arc walls. Whenever I extrude curves or surfaces the boundaries are correct but the surface itself is staggered/dented.
When I perform boolean operations it will recognize the surface and not the “correct” boundaries.
Tried to search the forum but couldn’t find anything regarding it. Changed tolerances as well.
