Surface transition / Match surface - Please Help
Good morning,
I am stuck at a surface transition and would be glad if someone can help out or give tips.
Match surface does not give me a clean result.
Maybe there is something I am missing?
I have marked the surface in red, which needs to match to the bigger surface.
Kind regards
match surface help.3dm (325.1 KB)
I’m getting a fairly good match here after matching the red.
Make sure your mesh settings are fine enough:
edit: I do see a bug here in Emap that makes the mesh settings not stick in Rhino 7
RH-79259 Rhino mesh settings do not stick in Emap mode
Run MatchSrf with Continuity set to Curvature
Refine the render mesh.
