I am trying to analyse the curvature of this vase - image and gh definition attached.
I have tried the component surface curvature (however this does not work). I have noticed changing the loft options makes a difference. However - I need the loft option to stay at 3 and still be able to generate a colour output which relates to the curvature of the vase. Your help would be much appreciated.
You need to use ‘Srf CP (Closest Point)’ as input for ‘Surface Curvature’. Then I noticed that curvature was mostly the same due to what appeared to be a few points with extreme values that were distorting the results, so I added ‘Eval’ to filter large values: “if(x>y,y,x)”
I know that this is an old topic but I am having the same problems but with another surface of coarse. Could you maybe explain the above solution further as it does not work on my surface and I need it as a general solution.
