I’m working on a vase script it works but I have a problem
I want it to always select the top surface of the vase, for the shell polysurface. this is the always the first trimmed surface in the list. the way it works now, you have to manually change the top surface (changing the number in the lower panel).
I’ve made many vase shapes like this and I too was confused by the OP. A real vase will not have a closed top, right? So the question about establishing a top surface did seem odd.
A vase shape needs an inside, an outside, and a bottom that has some thickness - typically equal in thickness to the sides of the vase. Once the outside shape is established the rest is easy. In this case making this:
