Sun - saved positions
Is there a way to save different sun positions so that they can be activated quickly?
A bit like named cplanes or named views.
You can use Snapshots for that. In the save snapshot dialog under Rendering settings check Sun.
I could not find that option.
Is that specific to Rhino render or to all render plug-ins?
Hello - Snapshots is a panel - you can open it from the Panels menu.
AFAIK this isn’t renderer specific. @lars would be able to say whether that is correct or not. I just talked with @lars, the sun section as posted in my screenshot should always be there.
Are you using a specific render engine other than Rhino Render, and if so, what engine is that?
