SUGGESTION: Curvature Graph UX
There is an aspect of the curvature graph panel that I find distracting. When the tool is active and it is switched off with the toggle, the surface still previews the extra analysis isolines on the surface. I think that the surfaces should display in their original state when the analysis is toggled off (but active).
Thanks
Before analysis:
Curvature Graph on:
Active but switched off:
Plus all of the suggestions from this post:
Definitely variable scaling per U / V directions, and graphs that are independently switchable for each isocurve.
thanks for reporting
RH-97913 CurvatureGraph keeps showing extra isocurves
Another UX tweak that I think would be useful when shaping surfaces using the curvature graph.
Thanks
Single-span degree 7(U), 5(V) surface example
With the curvature graph on, it would be helpful to be have an option to line the graphs up with the CV locations (currently they are evenly distributed across the surface).
Control points (CVs) are not directly tied to a location on a surface. Each control point of a single span surface affects the entire surface. (Surface edgesa only affected by a subset of “outer” control points.)
Thanks for your clarification @davidcockey
However, when shaping each row of points, I want the ability to see what the curvature is doing at that particular location on the surface where changes are being implemented. I suppose what I’m getting at is for some way the user can display the graph wherever they want on the surface.
@Gijs any thoughts ?
That could be useful. My guess is simplest to implement would be to have the curvature graphs follow isocurves.
If the count is equal to the degree, you get what you want, correct? (assuming single span surfaces)
Yes, and be able to snap to cv row locations!
Yes, I suppose that is close enough! Although when the CVs rows are of unequal distribution the graph comes away, but just a bit.
RH-97913 is fixed in Rhino BETA
