I don’t want to disturb the thread above that was started just now. In testing, I got pretty confused about how this is supposed to work…
- Make a box
- In the
Renderingpanel, press the 00 Reset To Defaults button to make sure that everything is as factory-default. - In the
Materialspanel [which is completely empty at this point], make a new material (e.g. green paint). - Sub-select one face of the box using Ctrl Shift LMB. Drag the material to the face.
I tried both dragging with Ctrl Shift and without keyboard keys. Sometimes I get a message saying that I can only drop 1 item at a time; sometimes this message doesn’t come up.
At any rate, I don’t know why I would be dropping 2 or more items?
Also, why does the mouse pointer read Copy? I am not making a copy of the material?
Going on then…
- With one face selected, go to the
Propertiespanel and click on the materials tab. Click onUse Layer Materialto override this.
Why isn’t the “Default material” listed in the Materials panel? - Click on the green paint material. The one face is now green.
- As soon as you do this, a
(unnamed)material is added to the Materials panel. Why is this one added? It’s not the “Default material” because now the material tab on the properties panel both has that “Default material” and the (unnamed).
I then proceeded to assign two more plastic materials to two of the other faces of the box. After that - somehow [that I cannot reproduce now], I changed the (unnamed) material to be glass. This made the three plastic materials turn into glass as well.
File in that state:
paint to glass 2.3dm (291.3 KB)
I tried to do this in a new file but didn’t find out anymore how to get the 3 plastic materials to change to glass at once.
When I then started undoing things to try to reproduce, I found that even when a plastic-material-turned-glass again became a plastic material, it still rendered transparent.
In Windows Explorer, this file looks like this (see the thumbnail):
But when I open that file again, it is back to normal:
