I wanted to note an odd bug when using Sub-Object material assignment. On some Breps, when you select a single subobject (command-shift-click) and ‘Assign to Objects’ the material gets assigned to multiple faces, instead of just the single face selected. Obviously this is not ideal.
Example:
Single closed polysurface with multiple sub-surfaces
Create a single new material and try and assign to a SINGLE surface:
Material gets assigned to two surfaces??
(Note also, the unwanted ‘Custom’ material is created and added to the scene: see link for more information on that)
I have attached the example file here for reference.
Environment:
- Macbook 2021, Apple M1 Max
- OS 12.5.1 (Monterey)
- Rhino Version 7 (7.21.22208.13002, 2022-07-27)))
thank you very much,
-Ed
@ed.p.may
material_assignment_example.3dm (3.4 MB)
