SubDs on Rhino 8
Hi all.
I tried to work with SubDs in Rhino 8 for a couple of minutes:
  1. '_SubDDisplayToggle or hitting TAB key or
    2025-02-20 14_20_32-SubD Tools 01
    … now register on the undo/redo “history” … this never happened on 7 and I can only see this as a regression. How to fix this?
  2. Soft creases and Hard creases are handled together width-wise. I would set a 2 pixel width for the hard ones but not for the soft ones… A different color would be best.
    It’s difficult to keep track of them! there is a way?
  3. Extruding edges with gumball or by holding CTRL key now sometime gave me a soft crease. I couldn’t manage to replicate this.
    There is a way to fully prevent Rhino from creating soft creases by its own? Because of point 2 above I would prefer to just create them myself when I know I want them.
Thanks in advance!
It currently registers as a repeateable command, but should not; I logged the bug here: https://mcneel.myjetbrains.com/youtrack/issue/RH-86156/SubDDisplayToggle-Never-repeat-this-command.
Adding SubDDisplayToggle to the list of Never repeat these commands should fix the issue immediately.
However, I could not reproduce it registering in the Undo list. If I make a SubDBox, then run SubDDisplayToggle, then Undo, the SubDBox command is undone, as it should. Do you have a procedure to reproduce that?
Agreed: RH-86159 SubD Display: Have a setting to change display of soft crease edges.
For now the only way to check if edges of a SubD are soft creases, is to select these edges (potentially select all edges of a SubD), then run SubDCrease. Post-selection works too, and the command will not modify anything before it is confirmed (escaping durign the command will not modify anything). Then click on a vertex in the SubD, and the labels will only stay on hard crease and soft crease edges.
Rhino should not make soft creases on its own, without running the SubDCrease command. So a setting is not needed and would not fix a bug where Rhino is creating a soft crease ex-nihilo. If you can reproduce this bug, let us know and we’ll fix it.
That works, I didn’t know about that options section.
I did a _Reset, now it doesn’t “Undo”.
I will.
Thanks, Pierre.
RH-86156 is fixed in Rhino 8 Service Release 17
