SubD crease - amount
Is there a way to change the amount and not have the crease 100% on or off? Best would be to set the crease amount on both ends respectively :slight_smile:
Thank You.
in v8 wip (latest release) use the subdsharp command
Saw your reply Thank you Kyle
@theoutside
Hallo Dale,
I had only tested the command briefly.
It worked fine. Shortly after, I had a crash.
When I work on the frame again, I will report.
Greetings T
Note: The command name in the v8 WIP is “Sharp”
