Display trouble Version 8
Version 8 SR15 (8.15.25019.13001, 2025-01-19)
hope this is posted in the correct place…
Does anybody know why I might be having display issues with any mode but wireframe ? what happens is if I select shade mode a simple item will shade but if I move the view at all the object will go to wireframe view even though shade mode is still selected. I either have to select the object again or select shaded mode off and on again… I did recently load most recent update.
update, isolated it to a SubD object
It sounds like that SubD object may have had a problem that was interfering with the creation of the render mesh.
Any chance you still have a copy of that object?
My guess is it would be helpful for the developers to see if they can figure out what the problem is.
I just redrew it
(attachments)
SubD Sphere.3dm (47.7 KB)
Also I did send in e-mail to support a screen capture video showing the occurrence later on after the forum post when I realized I could isolate the problem I was experiencing.
Hi Wudwerkz -
I suppose you will be getting help from eMail support and I’m just going to ask the same questions…
Please run the Rhino SystemInfo command and copy-paste the output here.
Already sent it in : was mentioned to update graphic driver….I did, still not working with subd shading, it’s the only problem
Rhino 8 SR15 2025-1-19 (Rhino 8, 8.15.25019.13001, Git hash:master @ 74164bdf5469c2f269746857c54b8c44b74c7b24)
License type: Commercial, build 2025-01-19
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Computer platform: LAPTOP - Plugged in [9% battery remaining]
Primary display and OpenGL: NVIDIA GeForce GTX 1070 (NVidia) Memory: 8GB, Driver date: 1-26-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 572.16
Integrated accelerated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
  • Secondary monitor attached to adapter port #1
Primary OpenGL: NVIDIA GeForce GTX 1070 (NVidia) Memory: 8GB, Driver date: 1-26-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 572.16
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 1.1
Anti-alias mode: None
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: Not supported
Driver Date: 1-26-2025
Driver Version: 32.0.15.7216
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.15.25019.13001
Sounds like you are getting help then.
Yes thank you. Brian James mentioned to me to go into settings and crank up settings , did work fme
