I would like start from the extrusion of the edges, the merging of the vertices / edges based on the distance…and so on always with the snap to the mesh…in Blender 2.82 there is a tool named politool , I hope in something like this tool…to start…and to finish in something like retopoflow ( an add on of blender https://blendermarket.com/products/retopoflow )… wishing is free…
You could start by running QuadRemesh on the scan object to get an initial retopo SubD. Then use Stitch to merge vertices and edge chains. Stitch would ideally keep edit points of the modified vertices on the scan object - at the moment it doesn’t but you can turn on edit points and pull them back with the _Pull command.
Thanks, but today I’m using retending blender with retopoflow … and I’m waiting for news on the new tools of McNeel’s subd … your work is fantastic … making it extraordinary is certainly possible
