Retopology
Hi, How can I do a retopology operation over a mesh model to creat a new subd modelling with subd faces? are there any osnap settings?
Check out this YouTube channel, where the “talking head” often does N.u.r.b.s. to subD or mesh retopology in Rhino. There should be some tricks you can learn there, even-though they mostly start with polysurfaces.
Currently, Rhino is kinda wack for retopology though. Something like Blender has superior workflows and should be more comfortable and way faster to work with, once you know the program a little. You’d do mesh to low-poly mesh retopology and then at the end apply a subdivision surface modifier to get something similar to a subD in Rhino.
Thank you : )
I need to watch exactly , with Grasshoper
Thank you : )
Like in the first video , But it uses endpoint of mesh edge, Tspline has a retopology snap to click touch any point of the object
Not just to the end point of the edge of the mesh.
This is just an example.
