Style edition issue
It happens very often that Rhino crashes when editing VisualARQ style parameter meters. Most often for railings and curtain walls…
Hi @guillaume.dupas In which VisualARQ and Rhino versions is this happening?
Does that happen in a specific file? can you share it?
Do you get a crashdump message when that happens? (if you do, please rename the crashdump file generated on your desktop before you close the Rhino Crash message. Zip it and send it to visualarq@asuni.com).
Hello, I’m on rhino 8 and visualarq 3.0.13.19113 but it also did it before with the other versions.
No error message, rhino unlocks but sometimes after more than an hour. This happens even on a blank file in no object inside, when you change a style setting or even when you click on a menu. It’s systematic when the style is complex (many elements). I have the impression that what is problematic is the modeling of the preview in 3D…
FYI, my PC:
Hi @guillaume.dupas can you share a sample file and indicate exactly which parameters are you editing in the curtain wall or the railing style which makes Rhino crash?
Does that problem happen if you have Rhino with the other 3rd party plugins disabled? (except “VisualARQ” and "Tibidabo).
