I’m a beginner…
I started to work with blocks which contain sub-blocks.
Now I’m trying to assign materials.
On some I get there, for others impossible.
In addition I can’t reach a sub-block.
Should i explode them?
Why, I can’t select a sub-element,
in the block manager?
Should I export blocks and multiple files?
Hello - you should not need to - if you want to retain the blocks, you should be able to get there via BlockEdit - depending on what you’d like to do, you may need to set a block’s objects to have materials ‘By Parent’ in their properties.
