Assign material to block instance?
I cant seam to be able to do that, is it possible?
Hi Yianni,
it depends on the render engine used. If you double click the block, assign materials to the geometry inside the block, does it get rendered ?
c.
http://docs.mcneel.com/rhino/5/help/en-us/properties/material.htm
Review the Example using Parent material section.
Does this help?
