StructuralDesigner3D - New Rhino Plugin
Good morning everyone!
I’m excited to share that I’ve recently launched a new plugin for Rhino called StructuralDesigner3D.
StructuralDesigner3D enables you to create funicular, tensile, and pneumatic structures using Dynamic Relaxation — all directly inside Rhino (no need for Grasshopper).
The plugin is designed with a clean and intuitive interface:
  • Simply select your input geometry (meshes or lines),
  • Define the physical parameters (masses, stiffness, pressure, etc.),
  • And run the simulation.
Afterwards, you can refine the parameters, save your results, or integrate the geometry directly into your Rhino model (with automatic layer separation).
:triangular_ruler: In this first release you can create:
  • FunicularStructures → for compressive shells and arches.
  • TensileStructures → for prestressed membranes and cable nets.
  • PneumaticStructures → for air-supported membranes.
:floppy_disk: It’s also possible to save and reload your structures with all physical parameters preserved, so you can continue the form-finding process right where you left off.
I’d love to hear your feedback! :slight_smile:
You can find more information on:
Website: https://www.structuraldesigner3d.com/
Usermanual: https://structuraldesigner3d.gitbook.io/usermanual
