Tensile structure without kangaroo or any other external plugin
Hi everyone! i was wondering if there’s any possibility to create a tensile structure without kangaroo or any other external plugin?
Yeah, its going to require a lot more manual work though. I would just recommend a tutorial on kangaroo. a simple one would be more than sufficient to create something similar to this. on the other hand you can always just manipulate a surface with control points then cut the curves out that pin down the tensile material.
Use formfinder:
