Strange issue with Copy Paste causing linked block to import again
I have this really strange issue with linked blocks. The problem happened in two completely different projects.
Just now I copied a text in a layout. Ctrl+C triggers the linked block update or re-import?
I pasted this here from my clipboard:
Martin Siegrist
28.02.2026
Paste in the viewport duplicated a linked block.
@Gijs something for you?
I think I need a file that shows this behavior and steps to reproduce.
What I did:
  1. I placed a link block in an existing file
  2. I created a layout
  3. Placed some text
  4. Copied the text (Cmd+C)
  5. Pasted in a modeling view (Cmd+V)
  6. Nothing happens at this point.
Here’s a simple example with a linked *.step and *.dxf
The blocks are set to linked, referenced
copy_paste_issue.3dm (70.4 KB)
collet.stp (83.4 KB)
box_100.dxf (101.1 KB)
I select the text or curve in the viewport. Does’t need to be in the layout.
Ctrl+C causes the *.step file to re-import. I suppressed the dialog.
With the *.step dialog switched on, I see this:
@stevebaer please check my example shared above.
Would be great if you could fix this copy paste issue
That is an odd one. Thanks for reporting RH-93758 Copy and paste initiates linked block
@Japhy this might be related
RH-93758 is fixed in Rhino WIP
