I defined two blocks and then nested those into a block and then mirrored that block.
Then copy pasted those two blocks and got this question:
No blocks in file prior to defining it.
Hi Jorgen - I see that, thanks.
https://mcneel.myjetbrains.com/youtrack/issue/RH-39689
@Holo - it looks like this cannot be fixed in the current scheme of things as it collides with some other copy/paste issues for blocks.As of right now, it looks like this one will have to lose out.
@Holo - apparently I was overzealous in keeping you informed - Dale Lear decided between then and now that this behavior is actually just too weird and disruptive and he’s going to figure out how to make it work right.
