Hi!
I’m following this tutorial: http://tips.rhino3d.com/2014/10/modeling-complex-transitions.html
Around 2:30 he’s using WireCut using a closed curve. When I try the same thing, nothing happens. So my first question is why can’t I use Wirecut with the closed curve as in the video?
Then I tried a work around by not using a closed curve but instead cutting the sides one by one.
The first cut is fine, regardless of what curve I cut with first. But when I cut using the second line, I get some strange result.It looks like the cut is made in the orthographic views, but in perspective the part I wanted to remove with wirecut is still there. My second question is why this happens? Is this a graphics bug maybe?
Here’s the file I’m working on. I’m using Version 5 SR12 64-bit (5.12.50810.13095, 10/08/2015)
Modeling_complex_transitions.3dm (196.3 KB)
