The _WireCut command does not work correctly both in 7.5.21068.13001, 2021-03-09 and in 8.0.21068.12305, 2021-03-09.
It does not allow the selection of the part to be cut and ends the command without giving _enter .
Just tested in 7.5 here and it seems to be working on a simple box…
WireCut_Corretto_in_RH80wip.zip (3.5 MB)
This Video is rhino 8 wip
In version 7 SR5
(7.5.21089.5001, 2021-03-30) not correctly function
My procedure:
- _WireCut
- Click the curve [ENTER]
- Click the polysurface [ENTER]
- Set Command: (Direction=CPlaneNormal DeleteInput=No BothSides=Yes KeepAll=No and press [ENTER]
- Selection of part for deleting.
!!! This Step IS NOT Performed !!! …while in rhino8 wip is executed !!!
Version Number of rhino?
The last downlodable SR is ok
But the last Service Release CANDIDATE no.
Hi -
This seems fine in (7.6.21089.23001, 2021-03-30).
I guess it would make more sense to show what’s no working.
At any rate, please run SystemInfo
in Rhino 7 and copy-paste the result here.
Testing on another machine, you appear to be correct. The video above is on a 7.6 Daily that I needed for some other reason, on the current 7.5 RC (7.5.21089.500) I have installed on another machine I see this phenomenon - pressing Enter cuts through the object and arbitrarily removes one side - no choice for which part to remove. @wim
exactly Elvetosauro!
1st pc:
Rhino 7 SR5 2021-3-23 (Rhino 7, 7.5.21082.11001, Git hash:master @ 944c103dcfd368bc1974c8866461f0c7bf5ae9d3)
License type: Licenza Lab Not For Resale, build 2021-03-23
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 16Gb)
Primary display: Intel(R) HD Graphics 4000 (Intel) Memory: 2GB, Driver date: 8-6-2020 (M-D-Y).
- Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA Quadro K3000M (NVidia) Memory: 2GB, Driver date: 1-22-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 426.50
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-22-2020
Driver Version: 25.21.14.2650
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
C:\Program Files\Brazil 2.0 for Rhino 6\Brazil.20.v60_x64.rhp “Brazil for Rhino”
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Flamingo nXt 5.0 (fd53f8c4-546d-47d1-8820-e66c97645a97)\5.5.18347.11581\5.5\Legacy\Flamingo.Legacy.dll "Flamingo nXt Legacy File Reader " 5.5.18347.11581
C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Flamingo nXt 5.0 (fd53f8c4-546d-47d1-8820-e66c97645a97)\5.5.18353.6521\5.5\Flamingo.nXt.rhp “Flamingo nXt 5.5” 5.5.18353.6521
C:\Users\M58\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.0\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.0.0
C:\Users\M58\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\raytraced-blend-material\1.5.0\RaytracedBlendMaterial.rhp “RaytracedBlendMaterial” 1.5.0.0
C:\Users\M58\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\raytraced-materials\0.1.5+v7.4\RaytracedMaterials.rhp “Raytraced Materials” 0.1.5.0
C:\Users\M58\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\rhinopbrmaterial\1.1.4+v6.16\RhinoPbrMaterial.rhp “RhinoPbrMaterial” 1.1.2.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.5.21082.11001
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.5.21082.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.5.21082.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.5.21082.11001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.5.21082.11001
C:\Program Files\Rhino 7\Plug-ins\Calc.rhp “Calc”
C:\Users\M58\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2020.12.9.865\PanelingTools.rhp “PanelingTools”
C:\Users\M58\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2020.12.7.446\SectionTools.rhp “SectionTools”
And 2nd PC:
Rhino 7 SR5 2021-3-30 (Rhino 7, 7.5.21089.05001, Git hash:master @ 8c08ab365205eddee74c2829591c23a839506d31)
License type: Licenza Lab Not For Resale, build 2021-03-30
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 4Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GT 710 (NVidia) Memory: 2GB, Driver date: 9-30-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 456.71
> Accelerated graphics device with 3 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 9-30-2020
Driver Version: 27.21.14.5671
C:\Program Files\Bongo 3.0 (64-bit)\Rhino6\Bongo.30.rhp “Bongo 3.0”
C:\Program Files\Rhino 7\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.5.21089.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.5.21089.5001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.5.21089.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.5.21089.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.5.21089.5001
Both with the same problem.
Perfect!! this version is ok
Thx
Hi Mitch -
Thanks for looking further!
And thanks for you systeminfo, @c3services .
I looks like there were major changes to the Wirecut
command last month and some of that resulted in new bugs. As far as I can tell, all is good in 7.6 at the moment.
