STEP import not correct after update last week
I imported a STEP in the beginning of the week in Rhino 8 and everything was showing up like it has to be. This week there was an update of Rhino 8 and after installing the STEP file doesn’t import like it used to be, not everything shows up. When I import in Rhino 7 everything looks fine.
Rhino 8 SR11 2024-9-10 (Rhino 8, 8.11.24254.15001, Git hash:master @ d3c11108eae09fadc146928ba51b9b182a05303f)
License type: Commercial, build 2024-09-10
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 5-13-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 555.85
- Windows Main Display attached to adapter port 0
- Secondary monitor attached to adapter port 1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-13-2024
Driver Version: 32.0.15.5585
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 4.1.0.2288
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\import_STEP.rhp “STEP Import”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.11.24254.15001
Hi Tom -
We’ll need that STEP file to be able to troubleshoot this issue.
Thanks,
Hello Wim,
to what mail adres can I send it? It is over 20mb. I wasn’t able to upload it in the post.
Tom
Hi Tom -
Please use https://www.rhino3d.com/upload to upload the file and make sure to copy the url to this discussion in the comments field.
Done
Thanks, Tom.
I’ve put this on the list as RH-83827 File IO: Missing Objects from STEP
Hi Tom -
This change is the result of an attempt to fix an issue when a STEP file is imported several times and new block definitions are created for identical blocks that already exist.
You can read the discussion about this here:
This is clearly something that will be worked on further, but in the meanwhile, you can use the TestStepBlockHandling command to turn the current behavior off. You will have to use the No option in that command.
RH-83827 is fixed in Rhino 8 Service Release 12
