Hi there !
I would like to know how I can stack closed objects inside a cube to create this type of structure in rhino. I appreciate any kind of help.
Kind regards
James
Hi there !
Kind regards
James
Have you seen this topic:
As far as I know, those white boxes only come up when you are missing a plugin or component. Generally a window should pop up while its opening the file to display the missing components and try to find them. Hope that helps.
What Rhino version are you using?
