Hi all, The Split command lets you split U ,V or by Isocurve. Could split be by point to point on a surface? That would be non-planer too. Thanks
Hi Mark - ShortPath will provide a curve that is ‘point to point’ and this can be used to split a surface if the two points are on the surface’s edges. Not sure if I am correctly interpreting your query though…
Hi Pascal, thanks and I will sure give it a try
