Splitting domain values
What’s the best way to apply sub-domains? I’m struggling with it as I’m in a situation I’ve never approached before. I don’t even know if I am phrasing the question correctly.
Given a mesh of about 90,000 faces in this case, I’m calculating the angle for each. All good. What I’m trying to output is a visual depiction of the colour-coordination of those angles, where everything below 15 is red (unacceptable), and everything from 15-90 is a gradient of green (acceptable).
Where I’m stuck is getting those out puts to work. I don’t want to “split” the list into two (-15 versus +15), as ideally it would just remain as a single entity. I’ve done a serviceable work-around where I manually input the percentage break-point for red to green in the gradient colour mapper, in this case all numbers being 0-60, so the 15-break-point-value is at 25% on the slider.
TL;DR:
What I’d really like is to make all values below 15 as red, and all values of 15-60 to automatically go to the green gradient. Best way of going about this?
Normally I’d post a photo but don’t currently have access to the model.
Maybe this will be applicable as an example. It uses the Consecutive Domain and Find Domain components.
Find Domain.gh (11.8 KB)
Just saw a small error. I needed to correct for the list length.
Find Domain.gh (11.6 KB)
And, if you want to minimize the gradient effect, you could try this.
Find Domain.gh (13.8 KB)
Interesting - thanks a lot Ethan, I will try to snippet that workflow into the larger script. Seems to make sense! Ive never seen that Conesc node before.
