Split object into parts
Hello
there was a discussion on this subject here
Here I have tried another solution, it has some plugin, some of them could be skipped and other changed.
But the logic is
1)Generate a solid brep/mesh of the object, I use here Dendro to close the mesh, it is not 100 % perfect but seems to work here.
2)Generate points inside the volume
3)Cluster these points with K-Mean clustering for example
4)Calculate the center of the Cluster
5)Make a 3D Voronoi (intersection with object will be a plane or planar surfaces.
  1. Make solid intersection
12 pieces here
5 pieces
40 pieces
Bison is not exactly what wanted @martynjhogg has it is volume
Volume from 1.8138e+6 To 3.2192e+6
And if you want the most stable positions, use stable positions From Nautilus plugin
Branch to split LD.gh (5.1 MB)
