Split object into parts
I have an organic object I want to split into pieces. It would be ideal if the parts were roughly the same size, but haven’t had much success. Any thoughts would be appreciated.
Thanks
Branch to split.gh (4.2 MB)
Hello
there was a discussion on this subject here
Here I have tried another solution, it has some plugin, some of them could be skipped and other changed.
But the logic is
1)Generate a solid brep/mesh of the object, I use here Dendro to close the mesh, it is not 100 % perfect but seems to work here.
2)Generate points inside the volume
3)Cluster these points with K-Mean clustering for example
4)Calculate the center of the Cluster
5)Make a 3D Voronoi (intersection with object will be a plane or planar surfaces.
  1. Make solid intersection
12 pieces here
5 pieces
40 pieces
Bison is not exactly what wanted @martynjhogg has it is volume
Volume from 1.8138e+6 To 3.2192e+6
And if you want the most stable positions, use stable positions From Nautilus plugin
Branch to split LD.gh (5.1 MB)
Wow, this is extremely helpful, and much better than the results I got. I am going to look through this more closely. Thank you
As you object is not closed, there are still some problems.
Cap close one main hole.
The other require some little work
Thanks, yea the form will require some clean up. I was initially thinking it would be easier as a shell, so I had actually cut the base off the branch. When I saw your solution for splitting as a solid that makes a lot more sense.
This could be a very useful tool @laurent_delrieu !
I wonder if you could add a pair of dowels between each face to aid with assembly?
Yes it is possible
Rough version there, time to go to bed
Mesh split LD.gh (878.2 KB)
@laurent_delrieu you just referenced this post, and that reminded me that I never posted a picture of my project completed. I was able to 3D print the mold in the sections that you helped me split, then I cast and reassembled the parts. Here it is, and thank you again for your help.
