I have a tree that consists of multiple branches. Each branch consists of two elements with indices 0 and 1, respectively. I want to separate all the 0 indices in a separate tree and the 1 indices in another. This is simply done by using the ‘List Item’ component, two of them. I post a screenshot of the components:
Now, I have a similar tree with multiple branches but this time more than two elements (or two indices). The number of elements in a single branch is indefinite. How can I again do the same thing but with more indices per branch (the 0 indices alone, the 1 indices alone, …). Is there a single component that is able to do so automatically? I tried the ‘Split List’ component but this is only able to split two lists (List A and List B). I want to be able to give any number of elements per branch and grasshopper automatically splits according to the above criterion. Any help is really appreciated. Thank you very much!
I used explode component but is there another way to do it automatically rather than manually. In explode component, I need to add branches manually on the right side of this component!
